Thank you for the response, and yes i can understand the business that you are in has a range of deviating factors that you can't always control.
I will hold out and wait a while longer.
How much longer do you think i will have to wait? What has been you longest delay so far?
Regards
Jack
SandervG 1,521
Hi Jack,
Thank you for your post.
As I replied on your previous message:
I am sorry to hear you are still waiting for your Ultimaker Original.
The Ultimaker Original is at times a complicated product to produce, because of the many different parts it contains.
Because the technology is developing in such a rapid pass we can not store large stocks because they can very easily become obsolete. The downside is that sometimes, when a supplier is facing delivery-problems it will immediately reflect on us. We do our best to be as pro-active as possible about this and that is why we send you an email to notify you about the extended delivery time.
I am sorry to hear that your patience is running low, and if you insist it would be no problem to guide you through the refund process. I can connect you to my colleagues from Sales.
On the other hand, if you can find it within yourself to have a little bit more patience you will be able to enjoy the benefits of having an Ultimaker Original. It has been on the market for over 3 years, and has been able to stand its ground ever since. Something no other printer has been capable off.
If you want to get back with me through PM that is fine.
Looking forward hearing from you,
