Hey Robert !
Thanks for the reply. I dont know what happens with the fans, maybe the steel mounts are a bit bent so the blades of the fans scrape them and after a while make the fan go out of alignment. But as you can imagine i'm pretty much done with the 40mm's
Yeah i was thinking about making some new side panels to experiment with, but was just wondering how far i could go with "mods" before UM would say it voids the warranty. I'd like to keep the original panels partly because of the esthetics.(the printer is in the middle of my living room)
IRobertI 513
Have you replaced 10 sets of fans and they all make noise? That sounds like the worst luck on the planet if that's the case. If it's simply that the same fans keep shaking loose I would look at maybe changing how they are attached. Perhaps try longer screws and secure them from the back with nylock nuts?
I don't know how they would handle warranty on something like that. I mean, they've been known to be very lenient and help people out even when the user is at fault but if you go and start hacking the panels apart with a saw... They wouldn't replace the panels for sure (although I'm sure you could buy new ones) but they'd probably help you out if something else on the machine fails as long as you don't do something really stupid. If I were you and I wanted to do a mod like that I would replace the panels instead and keep the originals unchanged. Make new panels out of some cheap wood/plastic and attach those instead of the originals.
