Flexible PLA
zews
Posted · Flexible PLA
Can anyone tell me of a reliable source for flexible PLA that will print well in the Ultimaker 2.
What colors are available that you know of and where can I find them?
Is it available in quantities smaller than full spools? (Like Faberdashery sells)
    I tried several filaments.
    My conclusion is that flexible PLA is not flexible in comparion with the other options available.
    If your are looking for flexibility, Ninjaflex and Filaflex are very, very similar, both print well, and with a very good adhesion to the bed. I think fliaflex is a bit better, for me.
    At ebay someone is selling ninjaflex by meter, not cheap though.
    • 2 weeks later...
    Hi ProfePaco
    Do you have UM1 or UM2? Have you done any mods to your printer when printing with Filaflex? In their website they recomend changing the hot end. Have you come up with any of the problems listed there?
    Regards
    Hi ProfePaco
    Regards
    UM2.
    I have the Robert's feeder... you should use it.
    And, oil the filament! That's all you need.
    How hard would Fileflex be to print on a UMO?
    It is 'possible' as I have printed filaflex, ninjaflex and semiflex.
    Semiflex was the easiest - but it produces quite a hard flexible material.
    Ninjaflex is slightly powdery so it feeds great and produces a hard rubbery finished product.
    Filaflex produces a really nice stretchy but very strong product - currently my favourite (ninjaflex was for a year).
    To make it work I opened the extruder - and if you look at the bit above the drive wheel there is a small amount of space where the filament could kink - so I taped in a smooth piece of plastic to close up that gap.
    Then I drilled out a nozzle to 0.65mm
    Then I struggled a bit until I lubricated the filament with a really light covering of wd40 applied using @iRoberti filament cleaner and it works like a dream.
    Temp 245
    Flow 125
    speed 16mm/s (I know it is slow but it works!)
    Bed temp 0
    I print on a clean glass plate (stuck too well to PVA covered plate)
    I have done watch straps that need precision, 2 wall thick and bridging and it worked well.
        • 56 replies
        • 29 replies
