Adjustable/flexible filament spool to fit Ultimaker 2
zews
Posted · Adjustable/flexible filament spool to fit Ultimaker 2
I just received my first order of filament from Faberdashery. What I did not expect, was that I would receive the filament without spools. Although of course it makes a lot of sense, because it probably saves quite a bit in shipping costs over time.
The filament coils that Faberdashery sent me have a much larger diameter than the sample coil of filament that is on the spool that Ultimaker sent me. When I hold the coils against the back of the printer, centered around the filament spool spindle, the coils just barely clear the power cable. It is probably not a good idea to try and force this filament onto smaller empty spools (if I can find empty spools), because it is rather rigid, and I would most likely damage the filament trying to force it into a smaller diameter.
So I have a feeling that I now need to print myself some flexible and/or adjustable filament holder(s) specifically for these filament coils that will fit on the UM2 spindle. I have seen some on YouMagine and Thingiverse, but none that I could find seemed ideal for the UM2. Would anyone have a suggestion for a particular printable filament holder that would work well with the Faberdashery filament and the UM2?
    I don't know the exact size but there are a number of spool designs on Thingiverse, Youmagine etc. and this one https://www.youmagine.com/designs/loose-filament-holder-v1 claims to be sized for the Ultimaker in particular.
    On the other hand, some people recommend not using a spool at all, leaving the filament loose and letting it unspool from the floor; that way there is no drag from spool hub friction which could cause under-extrusion or other problems.
    With a coil lying on the floor, you also pick up an amazing amount of nozzle-clogging debris, particularly in a room with a 3D printer...
    Really bad idea, IMHO.
    First of all - the larger diameter is a good thing! Not a bad. I wish I could get other filaments with larger diameter - I have a bit of trouble printing the last bit of filament because the radius of curvature is too tight and I get underextrusion. I only print the last 1/4 of the spool on my UM Original.
    So spend $10 and get one of these turntables aka lazy susan - it's what I use for unspooled filament and it works great. You put it on the floor and it actually rotates as the filament is sucked up into the feeder.
    FWIW, putting it on the floor on a turntable works fine for me. I print mostly faberdashery filament. And in two years, I've never had a nozzle clog, debris-induced or otherwise.
