Ah. I get it. After seeing her other posts talking about cell growth, I think Jemma's talking about well plates, the plastic trays with arrays of wells in them, used in cell cultures, DNA sequencing, etc. http://goo.gl/NjBQUL
Jemma, printing a well plate should be straightforward. Printing more than one well plate at a time should also work; you probably want to go into Cura, and select "Tools|Print all at once", like gr5's saying. That way it will do all of the objects' bottom layers first before moving up to the next layer, etc. to avoid collisions.
I'll post an idea about PLA alternatives over in your MSDS topic. (Short version -- try t-glase).
Steve
gr5 2,069
This is a more complicated subject than you might realize.
Are you aware that you can do "print all at once" or "one at a time"? It's under the "tools" menu.
I'm not sure what a "well plate side" is and how one would be in the way of the print head. There are also some settings on the "machine settings" used just for this type of thing. One of them is "gantry height" which means if you print something really tall and then go to print something else you might bang into it somehow with part of the printer. Is that the issue? Unfortunately (maybe) this just puts tall prints back into "all at once" mode so maybe you don't want that. Or maybe that's okay.
There are other settings "minx" that may help also.
You can certainly hand edit the gcode. It's easier than you may think. The move command is G1 or G0 (there's no diff in Marlin) and then you can specify X,Y,Z,E axes and you can leave off an axis if you don't need it to move. After a little practice with this you could adapt the "tweak at Z" plugin to do your Z move automatically. Plugins are easier to mess around with than you might think - they are pretty simple.
What kind of printer do you have? And please add your country to your Location in user preferences.
Maybe a drawing or photo of the "well" would help.
