Importing g code into model space in cura
bob-hepple
Posted · Importing g code into model space in cura
There's a command in cura that I thought was like a back plot whee you could see the results of the code in cura. when I do this nothing happens, can anybody tell me what this command is for. Also when I import my stl file into cura the model does not come up onto the bed, only when I hit layers does it show.. Is this a bug.
    Can you explain a bit more what you mean? Not being able to see the model file definitely sounds like a bug. Probably related to video drivers if I had to guess. Are you able to see the bed itself?
    What 'back plot' command are you referring to? The layers view is showing what the gcode will do when it is printed.
    Sorry for so long in updating my question I have just tried the command
    Fileload profile from gcode
    I thought this would import the gcode and produce the model by it as in my first post in Cnc. World this would be called a BACKPLOT
    But when I select it and then a g code file cura freezes then I have to close cura down and re start.
    Am I barking up the wrong tree with this is it not a BACKPLOT .
    Thanks
    Bob
    It's indeed not a backplot function but just just to retrieve the settings used to make the gcode. But this probably only works with gcode generated by CURA. When CURA freezes when try this on a non CURA generated file that would be a bug in my opinion.
    Yes, File->Load Profile from gcode does NOT load the model. When Cura generates gcode, it outputs a comment at the beginning that calls out the parameters used (layer height, speed etc). Load Profile from gcode recovers this information from the comment. Not sure what happens if you use this on a file not generated by Cura.
    If you want to load gocde into Cura, simply use the Load model file... option and change the filter to .gcode. Note that in this mode, Cura only shows the layers view as I suspect reconstituting the 3D model from gcode is difficult and possibly problematic.
    Mmmm I'm barking up the wrong tree but when I have used this cura stops responding, and yes this is gcode cura processed
    Thanks for the replies
    Ok Just tried this and see the settings change then crashed
    but thanks for replying
        • 26 replies
