new firmware update cura 14.07. Fans strange work...
Posted · new firmware update cura 14.07. Fans strange work...
Good afternoon. after the new firmware update through cura 14.07. Fans strange work. they count the percentage of the height. The lower table is lowered the more powerful they work. is that a glitch? a new feature or automatic?
noticed that yesterday's video
    This has been the behaviour of cura for a long time. You can change it in the expert settings under the "Cool" heading. By default the "Fan full on at height (mm)" setting is set to 5mm which means that cura will slowly ramp up the speed of the fans so that by the time the print is 5mm high the fans will be going 100%. Personally I usually change this to 1mm.
    thank you! I forgot about it I guess.
    Hey guys,
    great Job on that one!!!
    Best thing that you see the Improvent on the first Print.
    I like the new start.
    Bevore the surface of the print was only smooth, when I waited and manualy took away the first Fillament.
    Greetings and Thanks
