heres a couple pics. thank you for the link that shows how to upload. haha
the corners lift up while printing. not on the build plate, but every layer. am i using too much heat on the extruder? (210c)
and also you can see the print quality looks pathetic. i dont know why they can get a perfect print at the factory, but i get terrible quality when i try. any ideas????
IRobertI 502
It would be very helpful if you were able to post some pictures of the problems you're having. A rough surface could mean many different things for example.
"Smaller details". How small is small and in which plane?
Bottom layers shrinking. If I were to guess I think you mean that you're seeing a "cave in" of sorts around the first 5 mm of the part perhaps? If so, it's likely that you simply need to lower your bed temperature which defaults (for some reason...) to 75C for PLA which is too much, 60C is much more sensible.
Here's how to upload images to the forum:
http://umforum.ultimaker.com/index.php?/topic/4525-how-to-upload-an-image-to-the-forum/
