After eliminating the Z screw and the guide rails, the only thing left was the tab on the back of the build plate.
When I inspected the back panel, I found some small marks made by the tab rubbing on the panel. This was after I reassembled everything so rather than take the build plate out, I sanded the back panel down and now I get silky smooth Z travel again.
gr5 1,516
Don't know.
Is there lots of grease on your Z screw? There should be - if you touch it you should get lots on your hands.
