My printer may have the same issue.
The symptom is that sometimes the heaters work and sometimes (after a power cycle) they stop working. Especially if the machine has been on for a long time (more than 20 minutes) and I power cycle it, the 19V won't come on so that means the heaters and steppers won't work. You can verify this by going to maintenance -> advanced and moving the bed up or down. If that is broken as well then we have the same fault.
The problem for me was K1. K1 isn't needed and one of the designers of the board at UM actually told me I can bypass it so I did. But one fix was to turn off the machine for 30 minutes and then it worked. Another fix was to firmly tap the bottom cover under the board or remove the larger cover and tap the board direclty. When I do that I can hear K1 click on quietly.
It got so that I could predict if 19V was going to come on by the sound the machine makes when you turn on power. There is a very rapid "click click" when you power on the machine. The first click is the actual power switch and the second click is K1.
So I'm guessing you have the same issue. Let us know what you find. If you want to make it fail on purpose, simply turn on the printer, walk away for 30 minutes, then come back turn it off for just a few seconds and turn it back on. The heaters and servos should now be not working.
sensebellum 2
After much tinkering last night I found no solution (sometimes waiting 30+ minutes to see if it was truly "warming up").
This morning, I woke up to a working UM2.
A happy resolution.
