Posted · Remote print monitoring?
Hello,
Anyone got something working to remotely monitor its print while away from the printer & away from the local network?
I want to be able to see the print going through video and possibly abort a print if needed. could be a remote computer control. Just need to be accessible from outside the network.
I don't like leaving a print going while I'm away but when some prints take 15 hours and more its hard to be there and work full time at the same time.
I'll give a try with TeamViewer on Android and give an update. Share your setup :)
Thanks
    Hahha. I felt like that too. Are you running it on Mac? If so use the Terminal to run those commands... Its freakingly retarted but there is nothing else you can do really so just hang in there and You'll get it to run :)
