Thanks for the quick response!
I'm afraid that the results are a bit more drastic than the tilted print photo. It is more like the shifted layers photo (3rd right). See an example of a belt tightener I tried to print below.
I will try adding the spacers as suggested and report back.
Thanks!
gr5 2,196
I think you were filming slightly above where the problem is. The belt is rubbing against the wood near the motor I think. Try putting one washer under each of the 4 motor mount spacers to move the belt a tiny bit farther from the wood and the problem should go away.
If I am correct your prints probably tilt in the X direction (each layer skips a few steps so that each layer is placed a bit to the side of the layer below).
See 4th picture down on left side here and then click on it - the tilted gray robot:
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
Is that what you see when you print? Tilted prints?
