That's my theory also. Reheat the solder joints on that connector. Be warned there may be a "violates warranty" sticker on the connector on some of the newer UM2s. If not go for it. If there is a sticker contact UM Support first.
What country are you in? It makes a huge difference regarding support. Please update your profile settings location to indicate your country *and* then let us know if you have the sticker.
IRobertI 513
I'm guessing a bad connection on the sensor. Either a crappy solder joint or the connection to the bed connector. As the bed heats up thermal expansion makes the connection even more glitchy and starts sending weird readings to the firmware that eventually freaks out.
That's just my theory though, no idea if there's any validity to it.
