There are 282 steps per mm of filament.
If you have the motor power on 1500mA you are running the motor out of spec, generating more heat on the axis, and potentially damaging the feeder motor. Also wondering how you did this, as the default limit is set to 1300.
donmilne 2
Can someone with a knowledge of the UM2 firmware comment on this? Does the feeder advance filament in discrete steps, and if so, how does it cope with fractional steps? Particularly, a long sequence of fractional steps.
Or is the question misplaced? Should I view the printer as a simple robot and refer the question to whatever generated the gcode, i.e. Cura?
