Perhaps I don't understand your question.
But I am 99,9% sure, that a professional CAD system like Solidworks, gives you a choice or options on how to calculate your STL
If you want something more "visual", then in MeshMixer:
- import your mesh
- press W to activate wireframe view, so that you can see the faces
- select Sculpt
- Select Brushes > Reduce
- "Paint" on the model
- Play with Properties, mainly Size and Strength to adjust the effect
- Press Ctrl+Z to undo the change you don't like
Thanks guys, I tried both Meshlab and Meshmixer with your instructions and they worked fine. LOL how on earth did I miss Quadric edge collapse decimation, so self-explanatory. As for Meshmixer, “blah blah brush reduce” does not appear in their “user manual”. Both these packages are I think very powerful/useful but for someone like me, with no background/training in meshes, they just seem to be totally non-accessible without any decent documentation. No idea how you guys have become so knowledgeable! Still now I know how to use one function J
Hi 3Dcase yes I think you probably misunderstood my question. I am not trying to create an stl; I have a step file imported into Solidworks which has too many faces (88,000+) and I wanted to reduce the number, say to 5000 or below. For the testing I wanted to do, my Solidworks environment is too slow with any object with so many faces.
It's "the google".
Google knows everything. I have had to reduce qty of faces (had over 10 million on this crazy thingiverse scanned image) and so I had to google around and it worked so well I saved the link in my "ultimaker tips" file.
gr5 2,210
Detailed instructions here:
http://www.shapeways.com/tutorials/polygon_reduction_with_meshlab
