Polishing Bronzefill filament
lbeentjes
  • 7 months later...
Posted · Polishing Bronzefill filament
These discs are doing a good job on the polishing of the metal filaments from Colorfabb: Habras discs. http://www.keystoneindustries.com/en/rotary/hatho_habras_discs.html
Different grids embedded in a polyamide brush, yellow-80, red-220, blue-400 grid. Perfect for irregular surface and hard to reach parts. There is almost no heat generated, but keep it moving...
Finish with a soft cloth with Brasso or polishing paste.
These examples, bonze and brass, were 5 minutes of work
Habras discs: yellow-80, red-220, blue-400
polished bronzefill and brassfill
    Great job peggy, will look into these disks.
        • 27 replies
