What robert said. Except that I believe it is caused not due to gravity but thermal expansion of the filament. It happens if the printer is upside down also.
Cool head lift is a huge improvement over not using it but even better is to print a tower or two objects side by side. But only if you want showcase quality.
IRobertI 516
The retraction will relieve the pressure in the print head but will not empty the chamber completely. Since the print head is still up to a temperature where the plastic can flow, gravity will eventually cause the material to drip out. Personally I just use a bit of tissue paper to quickly wipe the nozzle clean before resuming the print.
Retractions work well to prevent drippage during an actual print because there's just not enough time for the plastic to drip out during the rapid travel moves.
