This is the bottom layer. Does the next layer look better? For ABS try 245C instead of 260C. Also I recommend bed temp of 100C.
I'm not sure what the edge is - it might be overextrusion or dripping - leveling might be too high (but that will be fixed on second layer so try second layer). Might be flowing too freely at 260C.
merardo 0
If you are reducing the print speed to 75%, I think that you should reduce also the material flow, it seems to me that you have to much material on the edges and because of that they don’t print sharp.
