Need a new and improved UM1 leadscrew
Posted · Need a new and improved UM1 leadscrew
I see the UM1 heated bed upgrade uses a new leadscrew (um2 ?)
but I changed my UM1 into an UM+ with double the height.
I would like to use the new heated bed option, but for that I would need a new 60cm leadscrew from the new specs,
can anybody give me the specs and maybe a link to buy a longer version :)
    The new lead screw is attached to the motor. As in, they're a unit, not separate pieces.
    you're saying, they cant be separated to put a longer version on it ?
    Correct, the leadscrew is a integral part of the motor and cannot be separated.
    You can also use the old Z nut on the bed, with a printed connection piece. You do need to cut a piece from the alu-bed then. And adjust the steps-per-mm for the Z.
    We looked at this as an option for the upgrade kit. But it added more parts for us, which made it more costly in the end.
    I was hoping to share the parts of the kit, and just use the heated bed parts,
    but as the leadscrew is an integral part of the hardware and software upgrade, I will have to buy the complete set and just use what I need.
    And I will have to buy a second leadscrew for the height I need.
    Thanks for the info guys :)
