Thanks for your quick reply, you are right it is this fan making the noise, however it certainly wasn't running when we first switched it on, if that is the case then problem solved I guess but why does the fan run when nothing is printing/getting hot?
Oggie
IRobertI 502
There is no electronics fan on the UM2, do you mean the tiny little fan at the back of the print head? If so, it should be running at all times so that's normal.
