When I connect to the printer with usb over Octoprint I can still use the built in controls on the UM2 and trigger a print from the menu. I dont know if you can pause from a print triggered from octoprint but I wouldn't see why.
It should be in the Tune menu.
gr5 2,330
This feature is already built into the UM Original and UM2. Not sure how ti would work through usb...
You can print with pronterface once you have sliced to gcode files. Does pronterface have pause feature? You can get it here:
http://koti.kapsi.fi/~kliment/printrun/
