yellowshark 153
Indeed. I always manually feed 30-40mm of filament before starting the job to make sure all is OK. And I watch the1st layer go down before leaving the printer.
Try to heat up the nozzle so evey filament in the machine get melted, then remove nozzle clean eat, look if there is any parts that needs to be cleaned or may be a object that jam your material, if so adjust it correctly.
gr5 1,968
Probably clogged nozzle. For example sometimes the filament gets stuck inside the head when you first load it (never once it starts extruding). It might get stuck on the edge of something in there.
Or dust. Or cat hair or other stuff.
Also if you let the nozzle sit at 240C or hotter for a long time without extruding the plastic in the nozzle tends to caramelize into brown gunk.
You might have to burn it all out but I recommend trying the atomic method first if it's not extruding anymore:
http://umforum.ultimaker.com/index.php?/topic/4118-blocked-nozzle/?p=33691
