I have made a coupler in Duratron.
working temperature 310 ° C.
Cool! (Well, not literally)
I had thought 260C would already be on the limit for PLA - but you got good prints with 310C?
How easy/difficult is it to machine Duratron?
duratron is for 170°c continius
peek 250°c continius, does anyone try in peek?
Anyone ever did check the PEEK HT?:
PEEK HT is also available as a glass filled material
The new Victrex® PEEK ST material has been designed to give all the benefits of Victrex PEEK 450 with the additional that the operating temperature can be taken to over 300°C, improved mechanical performance between 150-200° C is particular enhancement in PEEK ST over the standard PEEK polymer materials. Reinforced materials are available with glass and carbon as a filler, and can be used up to 380°C.
Copy/Paste from http://www.fluorotec.com/peek-ht-materials/
I think @swordriff has done some tests with Peek.
PLA sticks to peek like flies to sh**.
glloq 0
hi,
I think I found the solution to print more than 260 without burning the coupler.
Here pictures of my first test with pla.
http://umforum.ultimaker.com/index.php?/gallery/album/1478-glloq/
I've also tried it with no problem with XT ColorFabb color.
I have to do more tests.
see you soon. :-P
