UM Original Hot End Problem
onkelgeorg
Posted · UM Original Hot End Problem
Hi all,
since a couple of weeks I have a strange problem on my UMO hotend.
When the filament cooled down after a print and is re-heated I have massive problems to remove it from the print head. There is massive pull required to remove the filament.
If I leave the filament in the hotend and start a new print there will be no material flow until I remove the filament, cut off the slightly thicker end (with a small rim at the end) and re-install the filament. After this procedure the print runs without problems.
This problem haven't occured within the first 6 months of printing. So I think something must be wrong inside of the hotend. There are no leaks or broken parts visible...
Any help is appreciated :)
Cheers,
Joerg
    I guess this has to do with the teflon part. Yes, this also happens to the UMO… at the connection with the peek a little bit of material disappears. When you take the hot end apart the teflon has a brown brim.
    Or there could be a little gap between the hot end parts bowden-teflon-peek-brass, not necessarily ending up with leeks.
    Evidence can be seen when you pull the pla and see a thicker part at the end.
    @Robert: Thanks for your answer, I will check it this weekend. Hopefully it's just a loose connection, but...
    @Peggy: Thanks for the images. After seeing the second image I am almost sure that the Teflon is damaged. My last prints looked pretty similar to your "before" image ;)
    btw: I am considering to ask a friend with a lathe to produce some of this parts. But unfortunately the measurements in the technical drawing of this part #1055A2P-B are not complete.
    Does some have the complete measurements of this part?
    There's a STEP file provided, import that into your CAD software of choice and you can get the measurements that way.
