Or you may simply have the fan speed set too high.
I don't understand either of the last two suggestions. If the fans are causing a temp drop (which they surely must) then shouldn't the heater controller function compensate? At 210 it surely isn't already 100% on?
Yes problem is at fan I realised.. But before last update there were no problem. It was compensating itself. I reduced Fan speed %100 to %30. And now makes no problem.
Thanks friends.
If the fan speed is set too high the heater can't keep up with the heat loss, particularly at higher print speeds, where it has to heat more plastic.
Anders Olsson 136
Does the temperature drop when the cooling fans start?
In that case your heater block may be sitting too low, touching the fan cap
