If you can print all the parts of an assembly at once and have them work depends entirely on the model. In some cases it might be enough to leave a 0.2mm clearance, in others it wont. It's impossible to answer without seeing the model first.
I don't know how you've built your assembly, if it's separate individual parts, separate sub-assemblies or multi-body parts. But you can uncheck "Save all components of an assembly in a single file" while saving the file in the options (Option button only available after choosing STL as the format). This will save each part as a separate STL but I'm not sure if it'll break apart subassemblies and it'll not separate multi-body parts I'm pretty sure.
Of course orientation will be the same as the assembly which might not be ideal so you'll have to rotate them in cura afterwards, or, open each individual part, add a new coordinate system and choose that system in the options while saving.
gr5 1,872
If you don't want the parts to be "glued" together as they are printed you want at least a .2mm gap between parts.
Also Cura has an option in "normal view" where you right click on your parts and choose "split an object into parts" and it will separate all the parts and you can move them far apart or print them one at a time, etc.
Solidworks also allows you to save only some of the pieces into each stl. I don't know how to use solidworks but I'm sure it has things like "export current layer" or "export selected" or "export each piece to different file" or most likely all of those features.
