DidierKlein 729
Thanks for the video SolidPrint i wasn't aware netfabb could cut STL files
I usually use MeshMixer to cut (there's a plane cut option).
For warping i guess you have to use a lot of brim to prevent this, i'm not sur it's possible to unwarp a print.
For PLA it's possible to change the object if you put it in hot water a couple of seconds (70°c - 80°c). You can then bend it a bit and when it cools it should stay in position. I'd say it depends on the object and of the amount of warpage
solid-print-3d 30
Or do you mean separate parts of an assembly? Cura has a split parts function.
I have to fit parts together often that require absolutely flat surfaces. Best thing to do is make sure they are stuck like crazy to the bed when printing.
maybe someone else has some insight to working with warped pieces.
Heat gun maybe?
Find the perfect temperature in the oven so that you can clamp the two pieces together, taking out the warp?
Belt sander?
