Posted · Maximum layer height
I have a stock UM2.
Is it possible to print layers 0.25mm thick? I had a go and the result was a very beautiful spaghetti cloud in the shape of a toy helicopter, but not terribly useful.
Poking around the net yielded ought. Any ideas?
    0.25mm layers should not be a problem for a UM2. I think you can even go to 0.3mm layers (i did 0.27mm layers).
    Just don't push the limits of extrusion too much. You need to have a good temperature (assuming PLA: at least 230°c) and a decent speed (50mm/s).
    What were the settings you used?
    I have been printing 0.02 to 0.1mm layers at 200c with a bed temp of 60c at 30mm/sec and got really nice results. Hotter was messier, and lower simply did not stick properly to the bed.
    So I suppose the next thing to do is try is to speed up at hotter filament temps and see what happens.
    I managed to print 0.2mm layer height PLA at 230C, 60mm/s with a build plate temp of 65C. To get this to work nicely, however, I had to increase material flow to 130%. This is the PLA that comes with the UM2.
    I have just received some PLA from ColorFABB and at the moment the difference is huge; it's butter-like compared to the glassy PLA I got with the machine. I am printing at 60mm/s and it it's working on some detailed stuff. I'm very impressed with this stuff.
