I did print it, 10mm tall. It was quite cool, but still too thick for my purposes. Maybe I just have to fiddle a bit more.
I do the same for my custom supports.
Maybe with some hack in the code you could tell cura to single lines on the open faces and provide non watertight geometries... Maybe...
I can't wait until we can start printing single lines!
Dim3nsioneer 557
Did you actually print it? I also found that 0.4mm is not thick enough for Cura (at least not without the fix horrible B setting). I once made a 0.5mm support and sliced it with Cura. And the width of the print is: 0.5mm! Cura does indeed draw two lines but one of them is drawn with just about a quarter of the volume and shifted by 0.1mm in respect to the other line. Very clever!
