You can also export collada files from sketchup and load those into Cura.
(And this has nothing to do with ini files. ini files contain settings, not the 3D model)
I also know from recent experience that you can export models in Wavefront .OBJ format, without the need for third party plugins (Pro version, I don't know if the free version does).
Cura supports OBJ too.
p.s. I hope you're aware that while Sketchup makes great looking visualizations, they are not necessarily suitable for 3D printing. It isn't just a matter of file format, it's a question of the file (in whatever storage format) describing a watertight solid model.
gr5 2,204
Cura and most other slicers use STL files. You can export sketchup files to STL files with a free plugin.
