This came up a while ago on r/3dprinting, check out this thread on tinkercad:
Really nasty stuff.
@Gr5 You would retain the rights to your design technically, but they would have an irrevocable license to use, sell, modify or sub-license etc. your stuff. -basically all the rights that you have.
In terms of licensing, autodesk usually lets educational use of their software for free or deeply discounted. They are sometimes not compatible with the commercially licensed version or contain an internal tag that's created from educational versions.
If you are making commercial models, you need to be making them from the commercial version. Functionally they are exactly the same, but you aren't suppose to be making monies on the educational versions. They sometimes make them incompatible so companies can't use a bunch of educational licenses and one retail license and say they're legit.
Anyways I'm not a lawyer so take this with a grain of salt, but do read those TOS's especially the online cloud based ones.
gr5 2,210
That would be incredibly nasty if the license made you sign over all your copyrights for projects that used their tool. What about if you use 2 different tools? Do both companies now own all your rights? Exclusively? That doesn't make sense.
Anyway, I doubt they would do that but it doesn't take long to read the click license. I usually just read the first sentence to each paragraph as they are pretty well structured and after a while you see things like "You agree to indemnify..." and I know what the whole section will say so I skip it. The first time I didn't know what indemnify meant but after looking it up once, it's now standard stuff and easily understood.
