I've also been having trouble with Cura failing to finish writing the Gcode completely. It's hard to pin point the exact circumstances it's happening under, though.
This is a bug with the current release of Cura and USB printing. There is a fix in the latest RC, however, I do not guarantee that USB printing is stable. (There have been general problems with driver stability, which is why the UM2 does not support USB printing by default)
http://software.ultimaker.com/Cura_closed_beta/
gr5 2,230
I recommend you create the gcode with Cura and then use pronterface/printrun. I have no idea what that log might be saying but the UMO and UM2 don't do to well with USB printing. In fact it's not officially supported on UM2. And I assume RigidBot has Marlin and uses arduino. So I recommend trying a different program to send the data (gcode). Also consider trying a different USB cable and a different computer. Or add a USB buffer of some sort to boost the signal. Or run the USB cable in a different path (away from EM interference - away from electronics and fluorescent lights).
printrun/pronterface/prontrface download:
http://koti.kapsi.fi/~kliment/printrun/
