Yes from what is visible, it looks a bit like layer separation, have experienced this myself!
I would also go with extruder temp too low!
Temperature was 210 indeed. Will try going higher. Thanks.
Look at this graph when choosing temperature's and speeds. At 210C and .2mm layer height the absolute max speed for a UM2 is about 60mm/sec (blue line in graph). You were too close to that absolute limit. I recommend you don't exceed half the max speed (30mm/sec should be fine at 210C). Anyway if you want to print 50mm/sec and .2mm layers then the graph tells us 240C is about right. I print at that speed often but if you want higher quality I would stick at 210C and 30mm/sec and be patient.
http://umforum.ultimaker.com/index.php?/topic/4127-um2-extrusion-rates-revisited/
Also note that different colors of PLA and different brands may need 10C or so hotter or cooler than the brand used for the graph test (UM light blue).
Dim3nsioneer 559
Try reducing the speed further or increasing the temperature. I guess you're not yet higher than 210°C?
