Posted · Can anyone slice this?
I've tried a few times and Cura just sits there and doesn't build the print time on it
I don't know if its a lousy model (perhaps) or there's something wrong in Cura
http://www.thingiverse.com/thing:275096
There are two files, one says "repaired" but I can't get that one to do a print time/slice either
Thanks!
So say we all! =)
    The part slice but it takes a while. Its still junk in the end and not printable.
    The model is doubled, half is with inverted normals and the polygons are all exploded. In other word your into a lot of work to get that model to work properly.
    If you look at it in XRay mode you will see that its almost all white. that mean that a lot of faces are overlapping.
          • Heart
        • 4 replies
