I try printing gcode models that I have printed before with succes. They all come out with the same problems.
So it must be hardware.
It can be:
1) nozzle is not the temperature you think it is
2) head has partial clog somewhere
3) filament is too big for bowden and gets stuck
4) feeder not working as well as it used to
Did you say you replaced the actual nozzle and you had the same problem before *and* after changing nozzle? That might eliminate #2.
To test #4 - what happens if you push the filament by hand (open the feeder). Set nozzle temp to about 220C and push hard on the filament - does it come out okay? You need about 3KG force.
Look at the teeth marks on the filament. Are they sharp like the photo here or different than this?
gr5 2,243
To post a picture click "gallery" in the top left of this page, then big "upload" button. Then edit or post and click "my media" next to smile icon.
