the quality improvement with kisslicer is enormous compared with Cura unfortunately.
do you have the model available? it would be interesting to see others print and compare the same model.
also do you know that's the best a dimension 1200 can do? or was that just 'coarse' mode?
joergen 2
there are a couple of things you could try to improve the print quality:
try ABS, PLA seems with some users a bit iffy (especially me), try another slicer: Cura is great, but slic3r and kisslicer manage a better surface quality with the same print speed... no idea why.
