Posted · Cura print parameters not taken into sd file
Hello,
I just received my new UM2, so I am still discovering how everything works. I get into some bumps where you could maybe help me.
The biggest bump is that whatever the basic/advanced Cura parameters I set, the sd file does not take it : for example the print speed is set in Cura to 50mm/s and then when printing the printer shows a 100% print speed!
Same problem with temperature and fans...
Am i doing soemthing wrong ?
    You set speed in mm/s not in %. So 50mm/s = 100%
    So if you check the speed in in the printer it will Show 100%.
    If you change it to e.g 50% you will print with 25mm/s.
    I dont think so.
    For the fans they are progressively being activated in order to reach the given speed at a specified height. These can be found in the expert settings of cura.
    There is no compability issue that we know of. I'd be very suprised if there was one.
          • Heart
        • 4 replies
