Posted · Foreign pictures in my design !
Not only in yours...
It seems that we now get 'random' pictures with the designs :wacko:
  • It is not all designs
  • It is consistent (same design always gives same wrong pictures).
In case it helps, here are 2 examples:
  • https://www.youmagine.com/designs/reptar-xy-version-two'>https://www.youmagine.com/designs/reptar-xy-version-two'>https://www.youmagine.com/designs/reptar-xy-version-two'>https://www.youmagine.com/designs/reptar-xy-version-two
Note that when you 'search' a design, the thumbnail image is correct (search 'reptar' for the above examples)
    Same here!
    All the photo's for my spool holder are not mine.
    https://www.youmagine.com/designs/spool-holder-for-loose-filament
    Just did a test: looking on your link to the spool holder i saw picts of buckle female and buckle male
    logged in i see the spool holder... Do you see the buckle also or do you see different pictures?
    Like the flower design of you XY blocks! ;-)
    But serious..To me this looks like a simple problem in the web programming. Should be easy to fix for the programmer ...
    Wait! eSherpa is both an electric cart AND a phone case??!??!?!!? Boy technology these days...
    YES! just put the case in warm water and it turns to a electric cart - put the cart in cold water and it transforms back to a iPhone6 case..
