You should include 2.85 diameter filament in your survey since that's what the Ultimaker 2 uses. Good luck!
In the "word of mouth" that is called 3mm.
How much do you spend on 3d printing?
How much what? Euros? Dollars? Hours? Garden gnomes?
Cookies, Nallath, cookies - what else :-)
Thanks for pointing it out! I will incorporate that
Good question! Its USD, and I will add that to the form. Thank you very much for pointing it out!
Cookies, Nallath, cookies - what else :smile:
Thats what I filled in (well not quite with that in mind, but hey, cookies could work)
tinydancer 0
