Using Ultimaker 2 with side fans removed.
marzvt
Posted · Using Ultimaker 2 with side fans removed.
Hey All.
I primarily do multiple object production prints where Im printing several objects at a time one at a time. I always print in ABS for the strength, temperature stability and flex so the side fans aren't used.
Printing this was I am limited to how many objects I can print at once because of the clearance needed for those fans.
Has anyone tried removing them and updating the printer settings for the new head dimensions? if so, what are they?
Thanks!
    If you look at the stuff I print at mrdesignworx.com you will understand what I need.
        • 2 replies
