re-install didn´t work for me. stl files are still without association to cura.
any other hints?
any other hints?
Try this
http://windows.microsoft.com/en-us/windows/change-default-programs#1TC=windows-7
Edited by Guestyeah, this part is very clear, it´s the syntax of the shortcut. cura uses parameters, it´s not just choosing an exe or bat file....
Hello, the solution is installing cura in root.. c:/cura or d:/cura and associate it to "Cura.bat" "open with..>>choose..>>explore file..>>cura.bat"
Ancient thread but I ended up here so others that need help may as well.. In your windows search type "default apps" scroll down to the bottom and select "Choose default apps by file type" (takes a bit to load) look at left column and scroll down until you find the file type you want to set the default program for ("STL" in this case) now on the right column select the existing app icon or the "choose a default" icon a new window will pop up and you can select your desired program from the list.
Cheers
I also wound up smack in the middle of a 5 year old original post. Playing off the last comment, I could not change default in the default apps system settings by file type page. There was no option for Cura shown or any choose another app there. However I was able to change it by right clicking an stl file and selecting Open with -> Choose another app, More apps, Look for another app on this pc, Select Ultimaker Cura folder and then choose Cura.exe and click Open. Make sure to check mark Always use this app to open .stl files. Now it appears as default app and an option to pick in the Default Apps system settings, go figure.
Daid 301
Best way would simply be to re-install Cura. This won't wipe settings, and will allow you to bind the stl to Cura again.
