As layer height gets thicker you are trying to print more volume through that tiny nozzle. .3mm is TWICE the volume as .15mm. You are probably printing near the limit. Here is the max speed I recommend you print with on the UM2. The UM2 should be able to do double this speed but at a cost of quality. So I suppose if you really want you can increase these speeds by 150% if you don't care about quality much.
THIS IS FOR .3MM LAYERS
14mm/sec at 200C
20mm/sec at 210C
27mm/sec at 225C
33mm/sec at 240C
Data is from this graph:
http://umforum.ultimaker.com/index.php?/topic/4127-um2-extrusion-rates-revisited/
You might want to instead buy a larger nozzle for your printer if you want to make "draft" prints. A .8mm nozzle can print 4X faster than a .2mm nozzle (.6mm layer heights are reasonable or you can print .3mm layer heights but at 2x the speed of above table with stripes 2X wider):
Swordriff is selling these heater blocks and swappable nozzles:
umforum.ultimaker.com/index.php?/topic/7689-custom-heater-block-to-fit-e3d-nozzle-on-ultimaker-2/
yellowshark 153
Well assuming that you do not have a blockage in the nozzle or feeder system, the other variable (which you do not mention) is the print speed. In theory and indeed in reality you should find that a .3 layer is easier to stick than a .15 layer. But as you are talking about layer 1 I would have thought that the Basic profile would be using .300 for the first layer. Anyway what speed were you using for the 1st layer? If it is faster than 20mm/s reduce it to 20mm/s and see how that goes.
