Posted · I've just noticed something weird (Cura 15.02.1 layer issue)
Lately I've been struggling with some underextruding issues, which make the top layer of my prints a rather ugly mess.
Today, when sending a test print to cura, I noticed something strange on the top layers:
layer11
This is the top layer, and you can clearly see the holes between the lines. This results in a rough surface when the print is finished.
The weird part is that in the lower layers, the effect is less pronounced:
layer6
Until it disappears completely at layer 1:
layer1
I've tried fiddling with some of the setting from cura, but I can't get the top layer to be as smooth as the first layer. I admit I've no idea what might be causing this.
Have you run into this issue before? could it be a bug with cura, or is it something I'm not doing right?
Thanks in advance.
Here's the profile settings I'm using:
[profile]
layer_height = 0.1
wall_thickness = 0.4
retraction_enable = True
solid_layer_thickness = 1.2
fill_density = 100
nozzle_size = 0.4
print_speed = 60
print_temperature = 210
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_temperature5 = 0
print_bed_temperature = 70
support = None
platform_adhesion = None
support_dual_extrusion = Both
wipe_tower = False
wipe_tower_volume = 15
ooze_shield = False
filament_diameter = 2.85
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_diameter5 = 0
filament_flow = 100.0
retraction_speed = 40.0
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = 0.5
retraction_combing = Off
retraction_minimal_extrusion = 0.02
retraction_hop = 0.2
bottom_thickness = 0.3
layer0_width_factor = 100
object_sink = 0.0
overlap_dual = 0.15
travel_speed = 150.0
bottom_layer_speed = 20
infill_speed = 0.0
solidarea_speed = 0.0
inset0_speed = 0.0
insetx_speed = 0.0
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 3
skirt_gap = 3.0
skirt_minimal_length = 150.0
fan_full_height = 2
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 20
cool_head_lift = False
solid_top = True
solid_bottom = True
fill_overlap = 15
support_type = Lines
support_angle = 60
support_fill_rate = 15
support_xy_distance = 0.7
support_z_distance = 0.15
spiralize = False
simple_mode = False
brim_line_count = 20
raft_margin = 5.0
raft_line_spacing = 3.0
raft_base_thickness = 0.3
raft_base_linewidth = 1.0
raft_interface_thickness = 0.27
raft_interface_linewidth = 0.4
raft_airgap_all = 0.0
raft_airgap = 0.22
raft_surface_layers = 2
raft_surface_thickness = 0.27
raft_surface_linewidth = 0.4
fix_horrible_union_all_type_a = True
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config =
object_center_x = -1
object_center_y = -1
    something is off. Your screen shots shows fill is set to 0%, the profile you posted lists the fill as 100% but the layer view looks like fill is at about 50%.
    100% infill should be a solid yellow layer.
    reset the profile to default settings and then change fill to 100%. See what that looks like.
    Sorry, I was fiddling with the settings to see if something changed, and I think I posted a different profile file.
    I did as you suggested and reset the setting to default.
    Indeed, it looks completely solid again (as it should) at 100% fill density, but also at 0% fill density. The parts are 1.275mm in height.
    However, if I load the posted profile, the holes in the top layer appear again, even if I set it to 100% fill density. I wonder what could be the cause of this?
    True. That's why I thought weird when cura showed me the layer view and I noticed the crosshatch pattern. At first I thought the infill density might have something to do with it, thinking that perhaps cura might have overridden it for some reason.
    So I just changed it to 100% to see if that was the issue, but it wasn't.
    I'm still fiddling with the "faulty" settings, but I can't seem to find which one is causing this. After resetting the profile settings, it works normally, but I'm curious as to what might be going on here.
    Did you find out what it was?
    Only thing I can think is perhaps Combine Everything Type-A is doing something strange. Selecting No Skin under the Enable Combing expert options may help with a nicer surface finish as well.
