Thanks for your reply Tom,
I was kind of hoping that some of the heat may help to flatten out the layers. From my research the ideal temperature would be just below the glass transition point for any given material. If this happens it will be by good luck than good management ;c)
Also I'm experimenting with soldering the washer to some thin steel plate in order to mount it on the hot end blots. This will act as a heat sink, so it 'should' not get too hot.
I'm hoping to get some pictures of the design posted soon.
Oh and by the way, I will need to remove the cooling duct at the moment, but if this works, I might not need it :c)
Cheers,
Ian.
tommyph1208 55
That actually sounds like a cool idea... I would imagine that the washer gets hot from nozzle heat radiation though, so it wont actually be able to cool all that much... It the end it might only delay the curling...
