I have similar problems. The nozzle constantly clogs. The PTFE coupler is already new but still no difference.
korneel, that rail is nice but it takes a lot of space. I would prefer some sideways mount or even some support to put the spool under the table. The PTFE in my UM2 is like new, no signs of damage.
No you don't need that stuff. if your printer doesn't just print fine after atomic pulls and you ptfe coupler is fine then there is another problem, especially if you have roberts feeder.
can you push the filament trough the disconnected bowden without much resistance?
if you set the feeder to hard, cut away this part of your filament because it can be ovaly deformed..
but first do 5 nice atomic pulls if you didn't allready do that..
korneel 175
Emilio;
you could search for the rail system as well, it is listed under "U2RS" on youmagine.com made by UltiArjan.
i would also check your PTFE coupler.. it's the white little teflon part. it's probably deformed, causing clogs.
