Dim3nsioneer 556
3dSolex and their resellers offer 0.15mm nozzles. They are officially for UM2s but can be used in an UMO with an adjusted fan duct.
@Labern is maybe THE expert for printing small...
I have attempted to print with a 0,1 mm nozzle. While it is possible, you will need to turn down the flow rate, and for larger prints it will almost certainly clog and stop extruding at some point. You should probably clean both the Bowden and nozzle before every print, any debris will cause problems. But for smaller high detail prints the result will be great when they work.
Paoloboni 0
I'd like but i haven t find it..Where i can buy it?
