was hoping I could just set a base thickness and make the text height "negative" to have it cut out...I'll mess around with your suggestions.
How did you do the text in the first place?
import png, set base height then set text height, save to sd card then print
i did the base 3mm and the text as 13mm
Ok then just reverse your color.
hm?
I did my 3D text in blue. I would like a silver outline to slide over the letters...so it looks like the blue letters are raised inside the silver background.
Your png. Reverse the colors of the png. White background, black text
do you set a color in cura to be transparent or something?
I don't know for Cura but you can normally do that in most image editor.
You probably don't need to do this "reverse cut text". Just print on top. That's what I did but the key was that the text was .1mm thick and the part printed on top was bottom layer .3mm thick (with no cut outs).
DidierKlein 730
I don't think it's possible in Cura but with Meshmixer you can probably do a boolean of an STL text and a block
Or maybe with 123D Design (there is a text function there where you can extrude it)
