traumwandler 0 Posted March 21, 2015 in only vertical strings in infill Hi Guys, I got an ultimaker 2 and have some problems printing out objects. Maybe somebody could help me, I got some problems with infill. The infill doesnt look like it should. Its only vertical lines (but they are printed clearly) instead of a mesh This is a picture how the infill should look (cura) Here is a screenshot how it looks when printing: This problem occurs in lots of prints. Im using Cura 15.02.1 (Printer firmware 14.x) printing at 2mm³/sec - pla 210 degrees about 50mm/sec Infill 25 % same speed as rest of the print The outside object surface is very good I cannot find anything on the internet about this problem. (The other premade models from SD-Card print its infill correctly ) It occurs on lots of objects i want to print with Cura Share this post Link to post Share on other sites
IRobertI 428 Posted March 21, 2015 in only vertical strings in infill Try lowering infill to 24% or lower. The pattern changes when you go over 24%. Go into layer view and look at the infill at an angle while zoomed in, then step through the layers. You'll see what I mean when you go back and forth between 24% and 25%. Share this post Link to post Share on other sites
traumwandler 0 Posted March 21, 2015 in only vertical strings in infill Thank you for this quick answear. I notice, that the grid is going from 24 to 25 % much closer together. 24 % got a much bigger mesh. I will try it with my next print and tell if it worked. Share this post Link to post Share on other sites
IRobertI 428 Posted March 21, 2015 in only vertical strings in infill It's not just the size of the grid, it's how it's being laid down. Under 24% both directions are laid down at the same layer. Over 24% and only one direction is laid down on each layer. So on layer n you get lines going up and to the right, on layer n+1 you get lines going up and to the left, rinse repeat. Share this post Link to post Share on other sites
alexwimjan 0 Posted March 21, 2015 in only vertical strings in infill why not update the firmware from cura 15.02.1.???? Share this post Link to post Share on other sites
IRobertI 428 Posted March 21, 2015 in only vertical strings in infill If it aint broke, don't fix it? If the firmware is working well for your needs there is no reason to update the firmware. Especially since we've seen bugs creep into the firmware quite often lately. Share this post Link to post Share on other sites
traumwandler 0 Posted March 21, 2015 in only vertical strings in infill 24 % infill solved the problem. Thank you very much the firmware ... i never touch a running system Share this post Link to post Share on other sites
