I know this is not what you describe but I have noticed in one version, I think 15.02. that if you pause it will retract and move to the side and if you abort while paused it will then retract a second time as its homing. but if you abort from the tune menu it will just retract once.
But I have to also push the material in a bit at the start to get it going.
gr5 2,002
This is a bug that I have experienced also. Not sure if it's fixed in latest firmware but what I do is when I power on the machine and my hand is near the back I often grab the filament where it enters the feeder and slide it in a little more if it will go. The feeder motor has no power when you first turn on power.
