Like dinac said that looks perfectly usable. Heat it up a bit to make the plastic softer and thus easier to clean out. I like to use a q-tip which I twist in the cavity while it is hot (the PEEK that is, not the q-tip ), takes the leftover PLA right out. It might be hard to screw the brass tube back in if it's cold so once again, heat everything up a bit before re-assembly and it'll be much much easier.
peek problem
Thanks for the clarification. I wasn't sure yesterday so I went ahead and used another new peek. Thought I kept the old one(the one in the picture) just in case. I'll try to clean it and reuse it..
Hello!
In similar situation, I cleaned the peek part by dipping it in Dichloromethane (it works also with acetone, but it's less efficient). Out of the dip, you can finish the cleaning with a toothpick as PLA/ABS soften in the solvant while PEEK is insensitive to it.
Gael
aiiieeee. dichloromethane? Why breathe that when you could just heat the thing a bit and melt the plastic out?
Hi!
It works fine even if you don't breath the solvant and the cleaning is much more thorough this way.
You'll mainly feel the difference when you reassemble the head!
I can tell!
Gael
I guess it's a question of risk vs reward. I don't have a fume hood, so I prefer to avoid toxic solvents as much as possible, even if I get slightly less optimal results from less toxic options.
dinac 0
clean the thread , dont see any problem at all from pics
